Question on EGT Delta @ 8000ft DA and the effect of a different DA
I have read many places where a good test is to go to 8000ft DA at WOT and check your EGT Delta from full rich to peak and you should get a delta of 150 to 200 degress with 150 being leand and 200 being rich, 175 being the sweet spot.
The question is what effect would a higher DA or lower DA have on this Delta? |
Not much, it seems....
Brian, we just did a trip at 7500' with a 9350' DA and were around 1200 rich and 1404 leaned to peak. During winter months, IIRC, the overall temps were lower but the spread similar to warmer DA's. This on an IO-540 Aerosport,
Best |
Thanks Pierre!
| All times are GMT -6. The time now is 04:44 AM. |
