Reference Link
Thought I'd post this to help with the search function down the road. I've learned a ton from this site.
-Jim RV-10 want-a-be http://www.aeroelectric.com/ The AeroElectric Connection 6936 Bainbridge Road Wichita, KS 67226-1008 Fax/Phone: 316-685-8617 Keywords: pinout, avionics, radio, tools, wire, B&C, battery, coax, magneto, mag, wire stripper, alternators, antenna, batteries, circuit breaker, connectors, contactors, diodes, fuses, grounding, impedance, instruments, LED, motor control, primer, relay, starters, strobes |
Resources
Ditto! on the "Connection"
A couple of potential sources are: Batteries: http://www.digikey.com/ or http://www.sunnbattery.bigstep.com/ Radio wiring: http://www.approach-systems.com/test.asp |
| All times are GMT -6. The time now is 06:47 PM. |
