Big fat circuit breakers
I knew that'd get your attention George...
Question; where might I find a pullable 55/60 amp breaker for an alternator B lead? The usual suspects don't carry 'em, the closest is a 60 amp non-pullable from ACS. McMaster-Carr has a 60 amp pullable (pn 6608T1), but it's 45 bucks and would it be suitable? Then again, even a lowly current limiter with base adds up to 32 bucks... I'm wiring a Van's 60 amp I/R alternator; my current set up is the alt B lead goes thru a current limiter on the firewall then to the main bus. After reading/researching I'm considering going with a big breaker on the panel since the N/D "field" wire really isn't... Ideas, anyone? John |
How Ja know, uncanny
I looked up your pn 6608T1 refrence and got all excited when I saw it. Its a winner. Price wise you'll not do better, unless you buy surplus or can justify 50 amps (which cost 1/3rd). You checked the usual suspects, Wicks, Spruce, Wag and see a Pullable 50 amp CB, for $14.97 at Wicks, W23X1A1G-50. Spruce has it also about a buck cheaper. 50 amps will not do. :( I have a 60 amp Texas Instruments CB, part number: Ti #......6752-100-60 I bought all of my CB's, including the 60 amp CB surplus, most new condition. I did not pay anywhere near $45, but than I am a cheapskate. You can call surplus places and the guys that frequent the airshow circuit, I think they are from OK or KS have tons of this stuff at dimes per dollar. Sorry I don't have a name and don't know if they have a web page. Check "salvage aircraft parts". I love the hunt for cheap stuff. Outfits that handle corporate and airliners will have lots of CB's to sell. Otherwise shake loose with some coin-age you cheapskate, :D . George (yes you made my day) PS, I have an email out and will send you a private message if I can find a good used 60 amp'er for you. G . . |
60 Amp Breaker
Give B & B a call in Gardener Kansas.
913 884 5930, an Excellent Source AL Smith N495AB RV6 FF KEOS |
Well duhhh, I must hang my head in shame... I forgot to call Wentworth and White Industries for a used one. It's on my to-do list for today.
Me, a cheapskate? You betcha! I think it's a requirement be an airline pilot... John |
Yep B&B
Look here
50 AMP ELECTRIC CIRCUIT BREAKERS,MFG BY TYCO ELECTRONICS,POTTER & BRUMFIELD CORP. Part Number # W23-X1A1G-50. AMPS Rating = 50,250 VAC Max, 50VDC Max. |
| All times are GMT -6. The time now is 07:03 PM. |
