VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   Low oil pressure (https://vansairforce.net/community/showthread.php?t=5524)
N24YW 02-02-2006 07:23 PM
Low oil pressure
I noticed for the first time today that my oil pressure seems low. I havent flown the plane for a couple of months (doing some painting)and will be honest I dont scan the guages very often. but when I did tonight I noticed that my oil pressure was around 20 psi. My first thought was I had all my oil blown on the belly. So I landed and check it. Clean and at the correct level. My question is can I turn the pressure relief in to gain more pressure.
Engine back ground high time 2000 hours but good compressions and excellent log history. Vans pressure sender and guage. any ideas would be helpful.
jim
hngrflyr 02-02-2006 07:56 PM
If this is a new development, I'd cut the oil filter and look for metal. I would think some bearing clearances have opened up. If that's the case there should be metal in the oil. I don't think 20 psi is enough to protect the engine.
Bob S
Mark Burns 02-02-2006 09:45 PM
Low oil pressure checks
Jim,
I agree with Bob that you should check for metal, but hopefully you won't find any.
It could be a piece of "trash" caught under the oil pressure relief valve seat.
I'd pull it out and clean it up.
Mark
tacchi88 02-02-2006 09:47 PM
2000 hr. engine
If you've checked the oil pressure gauge and found it the be in working order, the engine itself is suspect. At 2000 hrs.. good compression mean little, and even if the engine was new. Just consider how differential compression is performed. The suggestion was made to examine the oil filter, and addressing the 2000 hrs. are most likely a good starts in curing the OP problem.
T88
sf3543 02-02-2006 10:25 PM
As Tachi88 says, make sure you have verified the gauge but don't forget the sender and the electrical connections. Could be as simple as corrosion on the terminals.
mahlon_r 02-03-2006 05:25 AM
My advice would be to check the gauge for accuracy before doing anything else. Keep running to a minimum while trouble shooting and don't fly it until the problem is resolved.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at you own risk."
