LSE harness 9 pin connector
I'm putting together a Plasma 2 system on my IO360. Looks like I'll have to disassemble the 9 pin connector to get the the harness through the firewall to the hall effect module. Is there an easy way to do that without wrecking it? I see some tiny tabs on each side, but don't want to apply too much force until I find out how it's done.
LS harness
I asked Klaus the same question. He suggested not disturbing the wiring. Just remove the shell and get the pin/housing assembly thru a 7/8" or so hole in the firewall and close with SS overlapping covers. Bill
I realised after my post that the wire has two ends! The connector on the other end is easily undone, though it would mean removing those tiny pins. |
| All times are GMT -6. The time now is 04:16 AM. |
