"I" Lug on Starter Solenoid
Anyone know what, if anything, attaches to the "I" position on the starter solenoid.
I have a ACS keyed ignition switch with starter position. Thanks! |
For some PM starters that have a built in solenoid, you can use that terminal in this manner:
![]() Van's statement is that this will prevent the starter from staying engaged too long after the starter switch is released. |
Sounds like you have an old automotive solenoid----the "I" post was to feed full battery voltage to the ignition coil during starting, and bypass the drop down resistor.
You can also use it to power a starter annunciator light.
| All times are GMT -6. The time now is 04:15 AM. |
