Plasma - wiring question
I have a couple of questions on the Plasma Wiring;
The manual says "when connecting power supply, route the positive lead to a 5A pullable breaker and then to battery plus terminal, bypassing any electircal bus or master solenoid" Q. Is there any problems with wiring it to the Battery Bus (always hot) or must it go via a CB? Q. Input connector; Pin number 6 is for the Tach signal, I have the Vans IE VTACHGEN 2 attached to the engine tach drive which will be wired to the GRT/EIS. I asssume this overrides any necessity to wire to the Plasma Tach signal as well. Q; Output connector; Unless you are using a key switch (which I am not) it looks like this is optional, not sure about variable timing though, am I correct ? |
Wiring should be a) battery + terminal to b) 5a CB to c) On/off toggle switch (you can probably use the old Mag switch, but you'll have to rotate it 180 degrees so that "Up" is "On") to d) Plasma control box Quote:
Plasma
Thanks for that Bill,
mcb |
No, only when the battery switch is on. But if you have an electrical problem and need to turn the battery switch off, you would still want your ignition to work. Arguably, if the battery is the problem it might be a moot point. But Klaus offers a schematic for a backup battery which you can switch to in case of a complete electrical failure; the backup does not even need to be very large as the ignition does not draw a lot and it only needs to last as long as it takes for you to land at the nearest airport (you wouldn't really continue on if your main electrical system failed, would you?).
I think there is a terminology difference here. I am using the same designations as Nuckolls:
Wiring Schemes Differ
If you are using any of Bob Nuckolls' wiring schemes from "The Aeroelectric Connection", as many do, the battery bus is connected directly to the battery positive terminal and does not go through the battery contactor.
You can connect the Plasma to the battery bus through either a pullable breaker or fuse. Either will work just fine. |
For those wishing to wire it to the Master bus (so they don't inadvertently kill the ship's battery after shutdown) the backup battery is a good scheme. Just put it in line using a diode so it won't try to power the ship's bus, and you're good to go if the master dies. |
| All times are GMT -6. The time now is 04:11 AM. |
