Trim servo speed controller
JUST GOT MY 9A FLYIN AND AM IN TESTING PHASE. I HAVE A RAY ALLEN ELECTRIC ELEV TRIM SYSTEM. WAY TOO SENSITIVE. RAY ALLEN HAS A SPEED CONTROLLER TO, I ASSUME SLOW DOWN THE SYSTEM. DOES ANYONE HAVE EXPERIENCE WITH THE SPEED CONTROLLER. DOES IT WORK WELL? CAN YOU EMAIL ME AT JDMEDIC@COMCAST.NET WITH ANY INPUT.
JOE N459RV |
Suggest you look at TCW Tech's 'Safety Trim'. Speed controller with safety features. http://www.tcwtech.com/
Speed control
I used the Matronics unit on my 6A.
I'm not done building but I'm interested in the same question.
An inflight adjustable speed control would be best. (maybe with a switch?) I've heard from others that a slow servo is great at cruise speeds but can be annoyingly slow in the pattern. Likewise regular servo speed in the pattern is great but too fast in cruise. |
The Ray Allen system work fine.
The only problem that I have had with mine was I set it up backwards. It trimmed faster when flaps were up and slower when flaps were down.
After I switch the wires around and adjusted the slow speed voltage, it has work great since. Kent |
5V voltage regulator to the rescue
I used a simple 5V voltage regulator in the wiring harness to slow the trim down for cruise. A switch on the panel selects either the 5V source or full bus voltage when high rate is needed.
http://www.n91cz.com/VideoClips/Trim...lRate_0001.wmv higher res http://www.n91cz.com/VideoClips/Trim...lRate_0002.wmv |
I found that I never needed a speed controller. Just quick blips on the hat switch do a good job. I have both elevator & aileron trim.
L.Adamson --- RV6A |
Hi Joe,
Had the same issue with my 9a when I first flew it back in 2006. That big elevator trim tab makes for a very sensitive trim issue at cruise speeds. I bought the Ray Allen speed controller, got it set properly after a couple of flights, and it has worked great since. One suggestion, if you do go with the Ray Allen, mount it under the floor pan but drill a very small hole so you can access the speed control screw with a small screwdriver from the cockpit --makes for a much easier task of adjusting. Cheers, db |
TRIM SPEED
I set up my -6 with a speed controller, it has a swt. that changes it to fast when the flaps are not in full up. Works great. 700+ hrs.
| All times are GMT -6. The time now is 07:51 PM. |
