VAF Forums
-   RV-9/9A (https://vansairforce.net/community/forumdisplay.php?f=5)
-   -   3rd Year Performance #'s (https://vansairforce.net/community/showthread.php?t=50164)
petehowell 01-10-2019 05:34 PM
CHT's with Carb Heat
Originally Posted by petehowell (Post 1314770)
Steve and Doug,
Good catch! I even out the CHTs by applying partial carb heat. On the 3rd run yesterday I turned the carb heat off to see if it would make difference in speed or fuel flow(it did not).
My CHTs are usually within about 10-20deg of each other with the exception of #1 that will be a bit cooler.
I'll get a pic next time I am up.
Went on a Spotted Cow run tonight - this is how the CHTs balance out with a bit of carb heat:
FNG 02-06-2019 07:53 PM
I just bought an RV9A. Nowhere near those numbers. Is your prop constant speed? I?m just getting the aircraft disabled in.
petehowell 02-09-2019 08:26 PM
Yep. Hartzell, carb, dual EI,
petehowell 01-04-2020 03:34 PM
Time for year 13 numbers!
The morning was a bummer with the funeral for a co-worker's fiance, but clouds were clearing off, and I thought I would take the -9A up to get some yearly performance numbers......
Lower layer moving East - pretty nice day up at 7500! Pic looking south, you can see KANE in the distance.....
There's the sweet spot - about 150KTAS on ~6GPH! Let's see if the 4 way says it is true...I know the Dynon has a dead spot......
Numbers looking pretty good - stiff wind out of the west, but speed a little better than advertised!!
FlightRadar 24 captures the action!
Looks like the old girl can still get up and run! I also got this low and slow data point the other day, good for going nowhere at all.....
Still thrilled with my baby after all these years!
LettersFromFlyoverCountry 01-05-2020 09:00 AM
Get thee over to KSGS airspace. :D
weissfamily97 01-17-2020 03:53 PM
Numbers
It's crazy how close our numbers are.
I have a 9A with O-320, 160HP, and Hartzell prop.
I was getting 150KTAS after 3 direction check.
I just got my nosewheel pant put on (was running without) and am about to retest.
I'm hoping for another 2kts.
