VAF Forums
-   RV-9/9A (https://vansairforce.net/community/forumdisplay.php?f=5)
-   -   3rd Year Performance #'s (https://vansairforce.net/community/showthread.php?t=50164)
rv6ejguy 01-13-2018 03:47 PM
Good numbers and obviously LOP hasn't caused any engine problems after 1900 hrs...
seward747 01-13-2018 04:01 PM
Ditto the kudos for continuing updates here.
Going back over previous year's posts, I noticed back in DEC 14, with your CF panel overlay, your abbreviated T/O and LAND checklist under the D-10 got dropped. That was one of my favorite "features"! Or, maybe it just got moved?
Doug
Seattle area
petehowell 01-13-2018 09:48 PM
Check list
Doug,
It did not make the conversion - I will remedy that, pronto! Good call.
scard 01-14-2018 06:38 AM
Pete,
You're numbers have always made me wonder what is "wrong" with my airplane. Then I add fuel and go fly and it is all better.
Steve Melton 01-14-2018 12:17 PM
performance is consistent year to year. good data.
petehowell 01-06-2019 01:28 PM
Year 12 Performance Runs
Got out and up today to see how the old girl is doing at cruise.
Cloudy, but 02degC and a pretty nice day. She seems to still have it at 12+ years and 2096 hours!
O-320, carb, dual EI, Hartzell, mogas. Otto flying the legs.
Yep - The D-10A has the dreaded black spot - it is stable for now, so I am just leaving it. The D-10A and the EMS-D10 have been great for 12 years and I know Dynon will fix me up when time comes.
The snapshot:
Data from the runs was pretty consistent:
I think I'll keep her!
rightrudder 01-07-2019 01:38 AM
You seem to have a very healthy engine at 2000+ hours...congrats! But your CHTs vary by quite a lot. Have you thought of making some changes to the baffling to even them out?
Steve Melton 01-07-2019 04:46 AM
there seems to be some opportunity to even the CHT.
petehowell 01-07-2019 06:12 AM
CHTs
Steve and Doug,
Good catch! I even out the CHTs by applying partial carb heat. On the 3rd run yesterday I turned the carb heat off to see if it would make difference in speed or fuel flow(it did not).
My CHTs are usually within about 10-20deg of each other with the exception of #1 that will be a bit cooler.
I'll get a pic next time I am up.
BillL 01-07-2019 06:39 AM
Originally Posted by petehowell (Post 1314770)
Steve and Doug,
With the corresponding low EGT it was looking like mixture distribution. Clever use of carb heat!! After 2000+ hours, it can't be that bad :rolleyes:
