VAF Forums
-   COMM (https://vansairforce.net/community/forumdisplay.php?f=38)
-   -   Externally Mounted Wing antennas (https://vansairforce.net/community/showthread.php?t=50160)
rmcgann 11-05-2009 06:37 PM
G'day all,
I currently have top mounted and belly mounted antennas on my -10.
I am experiencing too much coupling from the top antenna (Comm2) into my GRT AHRS and looking at replacing it with another belly mounted unit. I don't think I can accommodate minimum separation between two belly mounted VHF comms. I am therefore considering moving the two comm antennas to the bottom of each wing.
I have heard a suggestion that mounting on a wing inspection plate may be possible.
Does anyone have any experience with mounting bent whips on the wing inspection plates? Pros/Cons?
thanks in advance
Ron
RV-10, VH-XRM
flying in Oz
