VAF Forums
-   Northeast (https://vansairforce.net/community/forumdisplay.php?f=62)
-   -   RV-7A instruction needed (https://vansairforce.net/community/showthread.php?t=49614)
Dean 10-23-2009 07:40 PM
Just finished my RV-7A and need to get a checkout for insurance purposes. The insurance requires 10 takeoffs and landings. Does anyone know if there is an instructor in the Pittsburgh, PA area. I currently fly a Glasair III so this should be a relatively easy requirement to fulfill. I've flown an RV-6 and assume the RV-7A will be similar. I cannot use my airplane for the training due to the FAA regulations (40hr flyoff).
Dean
aarvig 11-19-2009 10:11 PM
Excellent RV Transition trainer
He's not in Pittsburgh but all he does is transition train and do tech counseling for RV's. I used him to get my PPL and also some dual in an RV7. Very knowledgeable, professional and effective. I highly recommend him. Check out his website http://www.rvtransition.com
I mentioned he's not in Pittsburgh but you may work something out with him. Having a good transition trainer is worth your weight in gold.
Good luck!
Rick of Austin 02-25-2010 04:05 PM
How did it go Dean?
It would be interesting to hear how the first flight went and your comparisons of the GIII and the -7 flying qualities.
Rick
