installing dynon backup battery
My D-180 from Stein came with an internal Li-Ion backup battery wrapped in a seperate bubble-wrap bag. I assume I have to install this into the D-180 myself?
I can't find any instructions for doing this... do I have to physically open the D-180 to do this? Strange that it wouldn't come installed... |
There is a small access panel on the side which is easy to remove . Inside is the mate to the connector on the battery. Connect, slide battery inside, reinstall access panel and you're done. Very simple. So simple, even a cave man can do it?
They used to ship installed, but since the shipping services saw fit to turn on a number of customer units and run the battery dead in transit we now ship them separate most of the time. It's a quick and easy install too.
Cheers, Stein |
The click is normal, and the way the airspeed tape is displayed is also normal.
| All times are GMT -6. The time now is 05:39 PM. |
