VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   VMS1000C vs Lghtspeed Plasma II+ (https://vansairforce.net/community/showthread.php?t=49075)
crewdog434 10-10-2009 12:27 PM
NEED HELP!!! After a few phone calls to Klause (Lightspeed) and the fine folks at JPI, I realized my Dual Lightspeed II's won't work with my VisionMicro engine monitor. :eek:The E.I. output is 10 volts for the tach. The engine monitor requires 5 volts. Anyone have a fix for this problem? An alternative would be to use a tach generator off the tach drive. But, I'd rather not do that. I posted this question in the General Discussion forum, but didn't get many hits. Thought I'd try here as well. Thanks in advance.
gasman 10-10-2009 01:43 PM
http://www.vansairforce.com/communit...79&postcount=2
