Flying RV-9 + O-360 + Catto
Is there anyone out there flying an RV-9(A) with an O-360 and a Catto prop?
If so, could you tell if your prop has two or three blades, the diameter, pitch, and performance numbers? By performance numbers, I would like to know what your 75% power RPM is, ROC, max cruise, etc. Thanks! PS. For those of you who are flying an OT9 (Other than a -9), thanks but your numbers aren't going to help me. PPS. LA, NO, I do not want nor do I need a CS prop! |
You just don't know it... :) L.Adamson --- RV6A/Hartzell CS |
One light bulb at a time, please :)
And... it needs fuel injection....
What are your numbers? |
Hi Bill,
I have been flying an RV9a with an America's Aircraft built Eci 0-360/Catto 3 blade since March of 2006. I should note that this plane does have the James cowl/plenum which is good for a few extra kts in cruise. My 2005 vintage Catto 3 blade is Craigs older design. He has improved the tip design and gone to a more consistent CAD method of production since mine was built. Mine is a 66x76 whereas I understand he now recommends the 66x74 with the newer tips for 360 RVs. I understand the newer design gives slightly better climb and similar cruise speeds. I have done a lot of performance testing in the plane (as well as much x-cntry flying) and can tell you that my cruise between 9 and 13k d. alt at 62-66% power (a sweet spot on my plane) will always be between 162 and 167 ktas burning around 8-8.3 gph. This power setting usually, depending on conditions of course, has the rpm around 2600--a quiet/smooth point on my aircraft. If I want to push it up to 2700-2750 rpm (which I seldom do) and 75% power (at 7000-9500 ft) it will cruise in the mid to upper 170 ktas range. Climb from low d. altitudes with just me aboard and 90 kts gives me 2000+ fpm. I normally climb at 115 to 125 kts indicated and still see 1400 fpm solo--1000 to 1200 fpm with me and the wife/full fuel. The thing I like most about this set up is the efficiency in the 10 to 14000 ft range where the Ronz airfoil really likes to fly. The forum archives have several threads on this set up--you might want to do a search for more info. Hope this helps. Cheers, db |
Hi Stan,
Good to see the finished product---she sure is pretty!! Blue with silver trim or deep red with silver trim were my top choices--the blue looks great! Tailwinds! Cheers, db |
O360?
Bill,
Did you decide to go with a 0360? I'm contemplating the same since I live at almost 6k MSL. If you do, it will be interesting to hear the comparison 290 vs. 360. Ed |
Stan,
Thanks, those numbers are helpful. I've elected to go with the new 72" Whirlwind Ground Adjustable Prop so this will give me an idea of what I should see, at a minimum. |
Do you know what your fuel burn is at those power settings? |
| All times are GMT -6. The time now is 11:59 AM. |
