VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   Garmin 430/530 vs 196/296 (https://vansairforce.net/community/showthread.php?t=472)
Vern 02-04-2005 03:01 PM
I would appreciate comments from pilots who have used both panel mount and portable units in their RVs to comment on the everyday practical features and usefulness of the Garmin 430/530 vs 196/296 as well as cost -effectiveness for your typical RV mission profile.
Obviously the cost is the first huge difference; legal IFR usage another; hard install vs. simple install another.
Finally, for those who went with the 430/530: would you do it again after seeing the 196/296?
Thanks!
Mustang 02-04-2005 05:54 PM
I use the 430 and the 295 in a C-182 that we use for crosscountry from time to time. This aircraft was certified for IFR with the 430. The 430 is great since it also has a NAV/COM in it as well. The ground mapping is not much but the control zone/restricted area depiction is great.
The 295/296 is a whole other deal and cannot really be compared to the 430. I have heard of some pilots being able to run an A/P from the 296 but our tech guy says we cannot hook up the 295 or 296 to the S-Tech A/P in the Cessna. The 430 has the capability of running the A/P.
Sorry I cannot be of more help to you. My main focus has been more VFR with this aircraft although I can do basic stuff with the 430. We will have something like the 296 in our "8" when the time comes, but we would also like something that could feed into the A/P and EFIS for wind and drift info that would be permanent.
If you are not that close to doing your panel, wait a bit, because the technology is changing so fast that there could be something better in less than 6 months down the road. Garmin just released the iQue3600 for instance, a palm type computer with Garmin GPS on board. It has a nice screen orientation also, opposite to the 296 but with most of the same bells and whistles. Once again, it is a Palm Pilot and will not tolerate sub zero temps, so not suitable for permanent installation.
Cheers, Pete
Highflight 02-04-2005 07:24 PM
There's other options as well if you haven't made any hardcore decisions on the rest of your panel.
One way I'm leaning a lot is to go with the Grand Rapids EFIS (dual) and feed the Garmin GNC 300XL certified GPS into it as well as an SL-30 for VOR/Nav input.
That way, you get the internal moving map in the EFIS driven by a certified GPS signal. As a bonus, you get a teeny little moving map on the 300 itself as another reference.
Too many options; too little money. :(
Matt
RV7-A
JetPilot 02-05-2005 04:49 PM
Grand Rapids EFIS / 300XL Combo
Vern (Highflight),
I am in San Antonio. I am about to do the same thing with my father's instrument panel. Would you mind calling me so we can discuss what each has learned with respect to this setup? I would appreciate it.
Thanks, Steve
(830)734-3000
Baja_Traveler 03-01-2005 11:33 AM
Well, if you are looking for Legal IFR useage you can forget the 296. I purchased one several months ago (and absolutely love it), and every time you start it up you have to acknowledge a warning that it is a VFR instrument only and agree to Garmin Legaleze to not use it any other way.
I'm not in the air yet, but use it for turn-by-turn directions in the truck and rental cars (I do alot of traveling for work, so I get to write most of it off!). It will also occupy the panel of my -7 when the time comes.
Kai Schumann
Brian130 03-01-2005 03:55 PM
Kai Schumann
How are the turn-by-turn directions? I bought a bluetooth GPS and a program for my iPAQ and so far I'm pretty amazed (I guess I was stuck in the stone age). The problem is that I have to preload the states where I'll be because it's 3.4GB for the whole country. How's the detail, nav algorithm (too many turns? common sense routing), etc for the 296?
Blue skies,
Baja_Traveler 03-02-2005 09:46 PM
Turn by turn is really fantastic. The unit has only let me down once - last sunday in Borrego Springs I had it find me a place to eat, and it sent me about 500 yards past the actual address on a side turnoff. Usually it sends me directly to the doorstep of the address I enter - even telling me which side of the street to look. I have the 128 meg card for it, and have California up to San Francisco, 395 up to Reno/Tahoe, the I15 route up to Park City Utah, and I8 out to Tuscon AZ - which maxs' the card out. If I had the 256 mb card I could get most all of the west coast this side of the rockies on it up to Canada. As for the nav algorithm, you can choose fastest route or shortest route - I've used both, and found either to be useful depending on traffic. There is also the option of avoiding highways which is great to avoid gridlock. And of course - put it in the plane, push one button and you have all the aviation charts built right in. (they are updated by plugging into the computer and uploading the latest Jeppsen maps direct from Garmin)
Kai
Blue skies,
flyerfly 03-03-2005 09:30 AM
garmin 196
I like the 196 because of its great battery life compared to the color units. In time I am sure color will take less power then it does now but for now I get several more hours off the battery then the color units do. The 196 does not have terrain avoidance though...I use my sectional for that.
Baja_Traveler 03-03-2005 11:57 AM
Garmin quotes 15 hours battery life, 8 hours with the back illumination on. I have found this to be pretty close. used it in a rental car all day cruizing around denver and the ski resorts - never turned it off till I got back to the hotel. Must have been close to 8 hours operation and it wasnt close to running out of gas. Of course we are talking new battery here - as it ages battery life may change somewhat, dont know with lithium-ion batteries. As long as you bring the charging cable with you, I can't see batteries being an issue unless you happen to be Steve Fossett...
Kai Schumann
akarmy 03-14-2005 09:46 AM
I just finished flush mounting my 196 in the panel. Don't have pictures yet.
I built a small panel that fit above the radio stack. Took the GPS case apart by pulling the 5 screws on the back. Then took the front half of the case and used it as a template on some paper. That gave me a perfect outline cutout to work with. Transfered that to my panel plate and cut with a dremel tool.
Then to hold it in place I made 2 u shaped clips out of some .063 that plugged into the 2 finger holes on each side of the 196. I put a couple of small model airplane screws through the face frame into these clips which hold the GPS firmly in the cutout of the frame. The frame is held into the radio rack with 4 screws so I simply remove the frame and GPS together to pull it out to go home for database upgrades etc. I didn't decide to make it a quick release setup like some have.
