Fuel injection system flushing flow rates
A question for all of you seasoned mechanics:
I have a factory new IO-360-M1B with Pecision Airmotive fuel injection. I have flused up to the fuel servo and get good flow rates. On the engine side of the servo, I am only getting 4.3 PGH with mixture full rich and throttle wide open. Is this normal? I am thinking it is normal with no airflow through the servo. BTW, fuel pressure is 33 PSIG. |
The servo varies the fuel flow as a function of the air flow and mixture control. With zero air flow, you shouldn't expect a high fuel flow out of the servo. I wouldn't start worrying yet.
Sounds right...
That's the about the same as mine with AFP servo.
| All times are GMT -6. The time now is 04:34 AM. |
