Plenum design for the AFP Servo
I'm in the final stages of forming the intake plenum that connects Van's FI
snorkel to the AFP servo. Before I start laying down fiberglass, are there any areas I should rework from an airflow perspective? ![]() ![]() Right now, my concern is the sharp 90 deg turn into the AFP servo. Would it be better to contour the outside corner a bit or leave as is? I don't have any clear pictures of the inside corner but it makes an even sharper turn. Thanks, /\/elson |
What is the difference betweet the AFP throttle body and the bendix?. I assumed my Vans airbox would fit when I get to that point.
Al Grajek |
Differences
Hi Allan,
As far as I know, the Bendix has a mounting flange whereas the AFP does not. Also, the AFP servo is quite a bit longer than the Bendix. Combine these two differences and there is some additional work involved. Regards, /\/elson |
Flow test the duct
David,
Your part looks OK. Actually it?s the inside corner that is important. What flows best here is a larger radius or flat inside radius (like a ?D? port). In any case you can always send us the duct when you get it finished and we can flow it in the airbox to see how it effects the fuel control metering. ?One test is worth a thousand expert opinions? Don. |
Flat inside radius
Hi Don,
Thanks for the feedback. A flat inside radius (like an extruded 'D' bent around corner) ... interesting. I'll see what I can do. Any clues on what I should aim for before I start moulding back into a circle to join to the AFP unit? Thank you, |
Duct design
David,
Just blend the ?D? shaped duct (flat on inside radius of duct) back to round. If you do this within about 2? from the throttle body inlet it should work fine. You can increase the inside radius which would reduce the area in the curved part of the ?D? shaped port by up to 20%, and not hurt the flow into the engine. Send me a picture of the foam before you lay it up. Don |
Got it. Sounds like it might be a pretty tight fit w/ the cowling and all but we'll see how far I can get. I'll work on it this weekend and get some pictures posted.
Thank you, Quote:
Reworked plenum
Hi Don,
Tackled the plenum this AM. The horizontal line at the end of the snorkel marks the very edge of the AFP's servo inlet. What do you think? ![]() Thank you, |
David,
FWIT I wrestled with what you are doing for several weeks and could not create a plenum I thought was worth using. Seemed like the turn into the FM200 was too tight and too restricted in size, but it was never flow checked so it was just my opinion a result of it looking at it. It pitched the device a week or so ago as I got tired of seeing it. In the end (it was more work) I modified the cowl to accommodate the "Y" adaptor with straight in ram flow and a scat duct up to a filter at the left intake. The filter housing is home made out of aluminum. I know I suffer some take off performance with as the filter is a Brackett designed for the 172 but for now it works. Going to ram air after take off is noticeable as the engine surges up a hundred or so in rpm. What would be perfect is to figure a way to get a large K&N filter installed, an effort I may tackle some day. I have the proper angle ducting and the filter but have not figured a way to incorporate it into the left intake feature. It would work using internal air but that may be worse than with the Brackett filter using external air. I can not say enough good stuff about direct ram air. The engine seems to really like it. |
Explain please
David,
I?m a little confused. The black line is before the inside radius. If the green foam is the ID of the duct, how will that connect to the inlet of the FM-200? The inlet diameter on the FM-200 (3.25? OD) is 5.8? long. If the end of the green foam (round part) is going to be the part that slides over the FM-200 inlet then the part should work fine. Don |
| All times are GMT -6. The time now is 04:33 AM. |
