Garmin Avionics Current Draw
I am laying out my electrical system and need the maximum current draw for a few Garmin products that I plan on installing. Can't find the installation manuals on Garmin's website.
GNS430 GTX327 GMA340 Can anyone help ? |
Garmin Amp draw
Draw versus recommended breakers is two different things.
The 430 is a 10 amp breaker |
Whoops
430 is 10 amps
I'll have to look up the others. I believe the 327 and 340 are 5 amps. Darwin N. Barrie Chandler AZ |
RE: Garmin Avionics Current Dray
Steve,
For the Garmin products you are interested in the links below will get you the installation manuals. The first one is for the GPS 400 GNC 420 GNS 430 Series, and the others are self explanatory. http://www.garmin.com/manuals/143_In...tionManual.pdf http://www.garmin.com/manuals/GTX327...tionManual.pdf http://www.garmin.com/manuals/GMA340...tionManual.pdf Michael Stewart posted a lengthy message on the RV list some time back on how to find the Installation and Pilot manuals etc. from the Garmin web site. Message: #124785 Subject: more Garmin Appolo Manual Downloads Date: Sep 19, 2004 From: "Stewart, Michael If you are interested in other Garmin Install manuals or Pilot manuals use the RV list search engine to find and read the entire message that Michael posted. JD |
Electrical Draw
Garmin 430 GPS/Nav 2.13 amps Garmin 430 Com ? Garmin GTX327 1.5 amps Garmin GMA340 .5 amps ? |
Garmin
GNS430 requires 2 breakers 5 and 3, SL30 same. 340 audio panel 5, 320 TXP 3.
| All times are GMT -6. The time now is 06:48 PM. |
