Tailwheel Endorsement?
Do us old folks who have flown conventional geared aircraft in our past have to get a "tailwheel endorsemet"? or are we grandfathered?
Hi there,
Here is a good reference on the tailwheel endorsement requirements: http://www.richstowell.com/dragger.htm You can be grandfathered in if you have flown a tailwheel aircraft prior to April 15, 1991. That's the law... is it practical? :) FAR 61.31 is your best guide. |
I have the time logged prior to the date given..... Thank you for the interesting link; it was a very good source for the answer and good information a well.
Tailwheels
Those are good reads. Remember, tailwheel skills, like a lot of things in aviation, are all about currency. If you have been trained properly in the past it will come back fairly easily but you will get rusty. I had a reasonable background in tailwheels, C-140 through DC3 but when I was ready to fly my RV8, I realized that my last encounter with a tailwheel was 20+ years earlier. So looked up an instructor to get current. His comment was, "Well, your feet haven't atrophied to badly!" Thanks.. I think. :rolleyes:
John Clark RV8 N18U "Sunshine" KSBA |
John makes a great point. Currency and what you are "allowed" to do are two totally different animals. :)
Fly safe - |
first tailwheel instruction
I just had my first tailwheel instruction last week.
I read ahead, and thought I knew what to expect; however, there is definitely more of a "practised knack" involved than I forecast. I left the airport feeling a mite humbled, with a greater respect for conventional gear pilots, and with a feeling that when I get the tailwheel endorsement, I should be a better pilot for the training. (Still building an -A, however.) . |
I've had just barely enough time in taildraggers to realize how much you have to pay attention to them on the ground, and to realize that I really like that challenge. Almost all my time is in nose-gear aircraft, and my current 9A build will be almost exclusively for business travel (no dirt strips) so it stays as a 9A - but I've already decided my "repeat offender" status will be earned with a taildragger, currently set on a Harmon Rocket.
| All times are GMT -6. The time now is 07:20 PM. |
