VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   Electric prime mounting pictures wanted (https://vansairforce.net/community/showthread.php?t=4463)
McFly 12-08-2005 01:06 PM
I have an electric primer solenoid (ASC # 05-29823) for my Mattituck TMX-360. If you have a picture or website of how you mounted this unit, I'll buy you a beer if you are ever in Chico California. Thanks.
Rick6a 12-08-2005 02:23 PM
Electric prime solenoid
I don't really recognize the part number....mine is the Parker-Hanefin unit purchased from Van's catalog. As illustrated, I fabbed up a simple bracket to mount it to.
Rick Galati RV-6A "Darla"
hecilopter 12-08-2005 03:12 PM
Adel Clamp
Don't have a specific picture, but I simply used an Adel clamp of the right size to fit around the solenoid and mounted it to the firewall.
gmcjetpilot 12-08-2005 03:33 PM
No Primer mount is a good primer mount
Just a suggestion, many pilots who installed a primer on their O-360, say they wish they would have just left it off. Some even removed it later. Since you are in Chino, you will not be using the prime at all. My last RV had a O-320 and I used it on occasion. However on my current project, a O-360A1A RV-7 I plan on leaving off. Just a thought. George
McFly 12-08-2005 04:37 PM
Thanks for the suggestions
Thanks Rick. The mounting screw holes seem much closer together on my primer unit, I?ll check again though.
The adel clamp mounting is what I have been considering, I may come back to it. I wanted to see some other mouse traps before I commit.
George, I was going to leave the primer off but Mattituck was just shy of adamant that I leave it on. If I ever primed with the accelerator pump, I would incurr the wrath of Mahlon ;)
Look me up if you are ever in Chico, the beer is on me. Thanks!
vlittle 12-08-2005 04:59 PM
primer valve
The primer valve is fairly heavy, I don't think a cusion clamp will hold it permanently.
Here's what I did: I mounted it on the angle above and outboard of the battery box. After mounting, I lock-wired it into place as well. Two of the bracket rivets are in the firewall stiffener, giving it good support.
Vern Little RV-9A
painless 12-08-2005 07:08 PM
2 Adels better than one
I used two adel clamps on the engine mount.
I do agree that one adel would be a bit light so I opted for two and it seems to be quite firm.
Regards,
