A-model upper baggage panel from ClassicAero
Anyone have a problem installing the upper baggage panel from ClassicAero in slider canopy-model RV's? Mine will not fit up under the F-6111 ribs. I hate to cut notches in the panel to make it fit, but I don't see another way.
Mike,
Good to see you are getting back to work on your -9A. |
Mike,
You may have the tip-up model and not the one for the slider. Worth giving Luke Doughton or Anna at Classic Aero a call on this one as it should just slot in sweetly. Cheers, Greg |
cut the notches
I had to trim some small notches. Not a big deal, and it helps hold the top end of the panel in place.
Jason |
| All times are GMT -6. The time now is 04:04 AM. |
