What documents & procedures to get our 12s complete?
OK all you kolwledgeable procedure types, what documents do we as ELSA builders have to present the FAA for the inspection? Then after we can start flying, what are the requirements before the airplane can be flown normally (i.e. with passenger and cross country)? I have heard that for ELSA the PHASE 1 is only 5 hours. What is involved with a PHASE 1 for an ELSA RV-12?
Are there other PHASES and if so, what do they involve? My EAA tech. advisor has never done an ELSA before and I haven't found any other members of our local chapter who know much about it. I am builder #52 Info appreciated, Larry |
Check out FAR part 21.193. This gives all the required documentation. Van will supply this documentation. You should contact your DAR or FAA Inspector early and talk. Many DARs do not have function code 47, so start shopping.
Phase I testing is indeed 5 hours minimum. After phase I, phase II is normal operation, cross country, with passengers, etc. Biggest difference between amateur-built and E-LSA is that with E-LSA, if you are operating on anything below a recreational pilot certificate, you must have a make/model endorsement in your pilot logbook. And of course the repairman certificate requirements are different. n168tx(at)flytx.net |
Mel,
What do you do in PHASE 1? Larry |
Mel,
Can I assume since Van hired a professional test pilot to do it, we don't have to do spin testing? Do we have to load the plane to gross at forward CG and aft CG and do a full routine of tests (except spin?). I believe Van's will be giving us a POH so can I assume we don't have to generate our own tables for weight & balance, Vx, Vy, best engine out glide speed, runway length tables, etc. I am new to homebuilding, please be patient with me. Larry |
You should obtain and read FAA AC20-27. Even though it is primarily written for experimental amateur-built, a lot of the stuff is also in line with experimental light-sport. |
Question from local FAA Inspector
Mel,
As per your advice I am starting to bring my local FAA FSDO guy into discussion about my eventual certification of the RV-12 as an E-LSA. I pointed him to the verbiage on the Van's website, and he has responded as follows: "My concern is in the first paragraph that is "RV-12 builders may build and license conforming airplanes in the E-LSA category." Does your airplane conform to the LSA Standards? If the prototype is not certified how does Vans insure the components you have meet the standard. I think you need an answer from Vans for your kit." I think the gist of his question pertains to the parts that are already built, before S-LSA certification is complete, and how do we prove they are meeting "standards" when there is no S-LSA certification at this time. What is your understanding of this? Will the FAA retroactively give their approval? Just a little concerned there may be an issue here for us early builders. |
The prototype RV-12 WILL meet the standards once it is certificated as S-LSA. If he has to change anything to secure that certification, builders will have to make the same changes. There is no reason for you to prove anything until you turn in you application for airworthiness (8130-6).
When you have received all you kits, Van's will issue a form 8130-15 (certificate of compliance) that shows that all parts in your kit comply with the prototype aircraft. Until that point, you can't show any proof, nor do you need to. |
Hi Mel,
Yes 21.193 is the correct legal requirement but it has little to do with what the builder needs to present to you at the time of the requested certification and I think that this is the information requested by the person who started this thread. Things like how does he get the registration certificate, builders log if that is requires for an ELSA, the FAA required affidavit needed for registration and the things like Weight and Balance data and most forward and most aft conditions of Weight and Balance if those are the things you would want to see. Our local DAR has a nice email he sends out to us for EAB aircraft and he is still trying to get Function Code 47 so that he can help the six RV-12's being built here at Spruce Creek, so far the FAA has not moved forward to permit him Function Code 47. Best regards, Vern |
I guess I don't understand the question. Part 21.193 lists the documents that the applicant must provide to the DAR. These documents will be supplied to him by the kit manufacturer. As far as weight & balance, that must be calculated just like any other aircraft. You must weigh the aircraft and calculate the W & B. No builder's log is required other than enough information to show that the aircraft was built in accordance with plans and instructions provided by the kit manufacturer without modification.
| All times are GMT -6. The time now is 02:01 AM. |
