VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: AEX Trailing edge rivets & pneumatic sqeezer (https://vansairforce.net/community/showthread.php?t=4339)
Got2Fly 11-30-2005 08:44 AM
Came up w/ a way to use my pneumatic squeezer on the AEX trailing edge of my -10 rudder, so thought I'd share it.
Simply, I took a yoke and found a suitable bolt to go through the hole, then used a die grinder to adjust the head of the bolt to have a flat angle matching the angle of the rudder.
An pic of the tool:
The tool in action:
So, how did the rudder come out? Well take a look at the edge:
N941WR 12-09-2005 07:42 PM
G2F,
Check out my Aileron page and scroll down to the entry dated 5/21/04. If you have more wedges to drill the jig I show is very helpful.
Also, in place of the bolt you used, I ground down a pair of rivet sets to the proper angle. Either method works great.
