IO-320 fuel line
Does anyone have pictures of how you route the fuel line from the injector body outlet to the fuel divider on a 9A?
Tommy Rutherford 9A N924TR(reserved) |
INJECTOR LINE
Most factory aircraft go from a 90 degree fitting on the divider, more or less straight down thru the inboard portion of the intercylinder baffle, with a baffle around the line at that point. Then inboard to the injector if bottom mounted or forward and inboard if front mounted.
Not a great picture, but.....
| All times are GMT -6. The time now is 04:35 AM. |
