Superior IO-360 Alternate Air
My RV7 project is beginning to move onto the engine.
I have an IO-360 Superior engine. As I am injected I understand I won't need carb heat - but I have been advised I need alternate air. I have had a quick look through the Firewall Forward book but not found any information so far. An overview, links or advise would be appreciated. |
Alt(ernate) air is in case your air intake or filter gets blocked. If you have a Van's air filter use their snorkel and alt air door. If you are just using a hole/trumpet in the cowl in front of the injector, put some fine gauze over the hole and make sure there is a 1/2" gap between the cowl injector - if the hole gets blocked the injector can breathe from inside the cowl (take a look at an Extra 300 cowling if this doesn't make sense). Dan Checkoway also has a different solution.
Pete |
Pete,
I finally found some info late last night in an Engines book. Makes sense now. As the airbox in Vans FWF kit has a flap. Thanks for the info. |
| All times are GMT -6. The time now is 09:36 PM. |
