VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   No kidding weight differences? Carb/FI (https://vansairforce.net/community/showthread.php?t=42373)
wickedsprint 04-17-2009 04:36 AM
So it seems there are a zillion different configuration weights on the 320/360 series, some showing as little as 10lbs diff between a 360 and a 320. However, some of them show up to a 30lb penalty of an injected engine over a carbed engine, and I was curious if this was legitimate, or if the finished all up weights end up being about the same. I can understand the desire for FI, but definitely not if it is in fact 30lbs heavier.
mahlon_r 04-17-2009 05:30 AM
You have to be careful about the models and their configuration, you are comapring. The IO-360 that weighs 30 lbs more has a counterweighted crankshaft as compared to the carb'd engine that doesn't.
The weight difference between like engine models, where the engine is the same except one is fuel injected and the other is Carb?d is only a couple of pounds.
Good information here:
http://www.mattituck.com/tmxfaq.htm
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
