starting problems.
I have an IO-360 with dual Jeff Rose ignition. I am having problems starting. Any suggestions?
Hot or cold?
There are probabably a hundred questions (and answers) which might help troubleshoot this problem. Here are some that come to mind:
Does the engine spin and not start? If it spins, is the prop turning over slowly, at a normal speed, or at <relatively> high rpm? Can you confirm spark at all 4 cylinders? What is your starting technique? Does the engine fire at all? Which fuel injection system are you using? Is this a new problem (i.e. a new engine installation) or is it a recent development on an already flying airplane? |
| All times are GMT -6. The time now is 04:40 AM. |
