Errors in ASI Calibration Article, Kitplanes, Feb. 2009
The tables of ASI reading vs water manometer height in the "Maintain thy airspeed ..." article in the Feb. 2009 Kitplanes are completely wrong. All the values of water height that I checked are more than 25% in error. Strangely enough, the same author published a similar article in the July 89 Kitplanes, but the earlier article had correct data.
The following formulae give results that are within 0.1% of the "official" specs in AN 05-10-24: For ASIs in mph, water height (inches) =((1+0.2*(ASI/761.22)^2)^3.5-1)*407.51 For ASIs in kt, water height (inches) =((1+0.2*(ASI/661.48)^2)^3.5-1)*407.51 For ASIs in km/h, water height (cm) =((1+0.2*(ASI/1225.06)^2)^3.5-1)*1035.083 You can download zipped Excel and OpenOffice spreadsheets that convert between ASI reading and water manometer height. Correct data follows: Code:
Airspeed Water |
I'm assuming you have notified Kitplanes?
(extra characters to keep some forum software writer happy) |
Well this is timely. I just inherited a Meriam micromanometer yesterday which indicates .001 inches of water to 20", and I was wondering if it would be useful for calibrating aircraft instruments. Does anybody know if this type instrument is what is used by certificated shops for calibrating these instruments?
http://www.meriam.com/productcart/pc...8&idproduct=35 Thanks Kevin! |
Readings
Kevin: Thanks so much for giving us the correct info and publishing the links. Bill
Kevin, nice spreadsheet! It will make things easier, thanks.
(Ok guys, he's sitting there with a broken leg and an idle mind...somebody suggest a project, quick! <g>) |
I might also do some more prep work on my own pitch axis autopilot that works via pitch trim, using adaptive gains. I did enough simulation work with X-Plane last year to convince me that the concept had some hope of success. Now I need to buy a Parallax Propeller microcontoller and learn how to program it. |
ASI Cal SS
Thx Kevin for the SS
<<I've got lots of projects.>>
I was kidding. You're the last guy I'd expect to harbor an idle mind. Remember the thread Paul started some time back about "Who do you believe"? You're in my top three. Get well quick. |
| All times are GMT -6. The time now is 04:44 AM. |
