VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Autoplug crush washers? (https://vansairforce.net/community/showthread.php?t=41647)
Steve Sampson 03-30-2009 03:22 AM
I am running dual P-mags with auto plugs.
I am reluctant to take the plugs out except to replace, in order to inspect, because I have been unable to find a source of replacement crush washers. Is this just a local problem or have others run into this?
With aviation plugs you can heat/quench and reuse, but it hardly makes sense with auto washers. Thoughts? What are others doing in this situation?
Thanks.
db1yg 03-30-2009 05:27 AM
Hi Steve,
I ran into the same problem with my LS PIII ignition/auto plugs. This is what I did---others may have better solutions.
I cut the original washer off the auto plug (they don't seem to want to come off easily after they have been crushed) using angle wire cutters, measured the thickness and diameter of the washer, and went to my local NAPA auto parts and bought a supply of copper washers of the same dimensions. I now reuse the washers after the heating/quench and plug cleaning process.
db
az_gila 03-30-2009 10:16 AM
Like these...
Thanks.
..... it seems the auto racing guys like thenm in slightly different thicknesses...
http://www.bteracing.com/Detail.asp?sku=MOR71900
http://www.bteracing.com/image.asp?f...w=200&notall=1
The above are for angled seats. Also available for flat seats like the aviation plugs.
http://www.mawonline.com/google/PDS242660.HTM
Also at Pegasus racing...
http://www.pegasusautoracing.com/pro...asp?RecID=4699
Seems to be more choice at Summit Racing
http://store.summitracing.com/egnsea...4294842813+115
I'm sure that there is some equivalent in Yorkshire....:) Ask for "spark plug indexing washers"
Bob Brown 03-30-2009 12:34 PM
Thanks Gil!
I have asked for this information in the past...and got nowhere...thanks for knowing/looking/posting useable info on this topic. Gil, you're a real asset to this group. Kudo's to you.
