Compressor question
How often do you drain your compressor completely?
I know the manual says every day you should drain the entire thing, but this gets a little old after a while. I tend to open the valve (bought a 90 deg ball valve for the drain so it's easier) frequently to drain the water but leave it compressed most of the time. Thoughts? Thomas -8 flaps |
Its a matter of scale
One cannot argue that draining the tank after every use is not the best way to maintain the equipment. It is. Do I do it that often? Heck no. I have too much **** between me and the valve. I do it when I think about it. I bought a 20 year old compressor, 20 years ago. I drained it less than 50 times over that time period I'm sure. I moved to a new compressor a couple of years ago because I could no longer get parts for the old Kellogg and it needed an intake valve. I imagine this new one will last just as long.
Rick Galati RV-6A "Darla" |
Decompressing the tank every day only adds to the range of the fatigue cycling load and increases the wear on the compressor unnecessarily. Drain the water daily (10 or 15 seconds) and you're golden. -mike |
Do you leave the compressor "on" 24/7? If you only turn it on when you're working on a project, you can leave the bleed valve slightly open all of the time. I mean VERY slightly open, to the point where it the leakage is almost unnoticable.
Water will condense, then run to the bottom of the tank where it is forced out under pressure. |
That reminds me... I need to drain my compressor!
:D Maybe we should make it an annual event like the birthday calandar? Annual "Drain Your Compressor Day"! ;) I was just thinking, if you ran a hunk o' toobing from the 1/4" NPT port on the bottom of the tank to a valve mounted waist high in a convenient location (maybe to the sink drain if possible?) it would facilitate a better maintenance schedule! The air would push the water all the way through the tube until empty! Hmmmmm, maybe in one of my leisure moments? I get so many of them! :cool: CJ |
The condensation runs out of the tank and into the coils of tubing. The advantage is that the water is sitting in the plastic tubing instead of rusting the bottom of your tank. Once a month or so, I use the valve to empty out the tubing. The cool part is that instead of being all rust colored and full of ****, the water that comes out is clear. PJ RV10 #40032 |
Much Presure
Mike,
What you said is actually what I meant. I did not mean to imply "drain it multiple times a day". Heaven's no, I really meant once a "work session" would be good. I certainly don't do it even that often. I say drain it when you feel like it, and do as you say by just removing the water and not all the air. Even so, as far as fatigue cycles go, tanks are steel (which is more ductile and less susceptable to fatigue compared to aluminum) and have very high safety factors so the strains will be way down in the elastic range. I don't think tank fatigue should be a concern in our lifetime, even if one went to the extreme of pressure cycling the tank a lot. Kyle, Your post brought a chuckle. 24/7 -! I am building in the basement, so the compressor is there. On the basement doorway, easily seen while ascending the stairs, my co-builder (wife) put the letters "COMPRESSOR OFF?" I can say that it has helped me remember to shut it off once or twice! Too often, I shut it off at 2-3AM after it has startled us awake. :D |
I end up draining at the end of every work session. It's the way my dog knows it's time to stop working on the stupid airplane (he thinks) and go walking.
But I do have an oily substance when I drain it. Only occasionally. That bothers me. |
I drain mine once every couple of days (it's 60 gallons so it takes forever). I get oil too. That's pretty normal.
| All times are GMT -6. The time now is 02:06 AM. |
