VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Should I apply "form a gasket" . . .? (https://vansairforce.net/community/showthread.php?t=41521)
MS19087 03-26-2009 01:42 PM
Should I apply "form a gasket" between my FAB, spacer and fuel injection servo?
Guy Prevost 03-26-2009 02:47 PM
NO!
There are numerous stories, possibly even on this forum, about engine stoppages due to form-a-gasket, RTV, etc. being sucked into the servo. If a bit of air leaks between the FAB and the servo it's not a big deal; you might loose .01% horsepower. If the gasket winds up in the servo, you'll loose 100% horsepower.
Edit: Here are some instances of this problem. More than one case on this thread: http://www.vansairforce.com/communit...ght=gasket+fab
Just one persons opinion, of course.
Guy
Rivethead 03-26-2009 05:16 PM
I thought Form a Gasket was Permatex. I'd use a paper gasket with a very thin - applied with a Paint Roller in order to reduce squeeze out and keep the coat thin - coat of Form a Gasket Permatex on the paper both sides if I were worried at all that the gasket might leak. Most problems with sealents occur when they're applied like tooth paste.
glenn654 03-26-2009 09:08 PM
I would suggest using "Titeseal".....I've had good luck with it.
Glenn Wilkinson
f1rocket 03-27-2009 06:22 AM
Just this past weekend, I had to remove my fuel controller and elbow from my engine because a part was originally installed upside down. Both gaskets were installed by the engine manufacturer dry, so that's how I installed then back on the engine.
