VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Trim relay/Flap relay (https://vansairforce.net/community/showthread.php?t=4129)
rv72004 11-18-2005 05:23 AM
I am about to mount the trim and flap relays under my rhs seat to be as close to the stick grips as possible.
This seems to be the best option to me. Does anyone have a better location for some reason ?
mlw450802 11-18-2005 05:30 AM
Is there a reason you are constraining yourself to mount the relays close to the stick grips?
-mike
mgomez 11-18-2005 09:37 AM
-mike
That's what I was wondering. The relay's coil can't draw that much current. After all, the flap motor itself draws less than 1 A...surely the coil draws less, otherwise, why use a relay?
RV_7A 11-18-2005 09:44 AM
Most grips require use of relays to control trim and flap motors. CH Products now offer grips with relays built into the grips. But if you are using grips like mine (early model grips w/o relays built in) then mounting the relays close to the control stick makes for a lot less wires run. Here's how I did mine.
Jim is doing his a little different and very nice.
