1/4"id x 7/16"od bushings?
I'm installing the Dynon AOA/pitot using SafeAir1's pitot/AOA tubing kit. Their tubing is 1/4"OD. However, I'm using the one 7/16" hole Van's put into the rib and drilled a second hole of the same size adjacent to it so that I can run the AOA/pitot lines separately. Does anyone know of a source for 1/4id x 7/16od bushings? (The ones that came with the SafeAir kit are 1/4id x 3/8od).
Thanks, Steve |
Aircraft Spruce has those, Part # 04-05738. Van's also has them.
Roberta |
Thanks Roberta! Didn't even think to check Vans!
Steve, I bought mine from Sproose!
...but if you are cheap, like this frugal Yankee... there are extras in the pitot parts package that comes witht he kit! I discovered a them after purchasing the extras! It turns out that I will likely be using all that I have and then some, as the vapor return lines I am installing will need them too. :rolleyes: CJ |
| All times are GMT -6. The time now is 06:52 PM. |
