VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Fuel Pressure? (https://vansairforce.net/community/showthread.php?t=40774)
Mogli 03-09-2009 06:07 PM
Fuel Pressure?
Does anybody know at what fuel pressure the relief valve opens on the Airflow performance electric fuel pump? It's for an IO-360 (200hp) so the high psi pump. I'm trying to calibrate my engine monitor (AF2500). I can obviously get the 0 psi value put was wandering if the 30psi setting from the factory is accurate. Since I can turn the pump on and hold stable pressure once the relief valve opens I can verify the pressure reading in the cockpit.
Bill
RV-8
IO-360A1B6
