VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   servo motor connection (https://vansairforce.net/community/showthread.php?t=39428)
plumbflyer 02-06-2009 08:10 AM
I was wondering what is the best plugs to use for the wiring on the servo motors and where to get them. It seems like it would be better to have a plug in to be able to remove the motor if it has problems.
Rene Bubberman 02-06-2009 08:29 AM
D-sub pins and sockets
We used D-sub crimped pins and sockets from SteinAir http://www.steinair.com/connectors.htm because of the small space and ditto wires. More pics on http://websites.expercraft.com/PHVII...y&log_id=11115 These pins normally go inside a D-sub connector but can also be used individually with some heatshrink insulation. Don't forget to buy a good crimping tool.
N941WR 02-06-2009 08:54 AM
Radio Shack
Pick up some DB9 connectors from your local vendor.
allbee 02-06-2009 09:18 AM
solder direct and use heat shrink. cheaper , no corrosion, no connection problem
