VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   wire questions - strobe & flap (https://vansairforce.net/community/showthread.php?t=3892)
Scott Will 10-31-2005 08:06 AM
I almost have all my wires run... just have to make the connections. But I have two remaining questions:
  • What size wire to the flap motor? It comes with 20 awg leads, I assume that 's OK?
  • What kind/size of wire to the strobe power supply? Do you run the shielded 3 conductor wire or use regular wire with a ground run? If regular, which size?
Thanks for the advice!
Scott
Davepar 10-31-2005 10:10 AM
From what I've read, the no-load draw of the flap motor is 800 mA. Even if the current with load is 4 times that, you could use a 5A fuse with 20 gauge wire. Maybe even 22 would be sufficient. It's an intermittent load, so that helps as well.
I'm not positive, but I think you can run regular wire to the strobe power supply. It appears that is what Dan did:
http://www.rvproject.com/20030717.html
Dave
