VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Mounting ignition unit in a 7 (https://vansairforce.net/community/showthread.php?t=37490)
shiney 12-19-2008 05:11 PM
Has anyone any good suggestions for the best place to mount my ignition unit?
odlee 12-19-2008 06:30 PM
This worked.
This was mounted utilizing screws and nylocks. Others ways would be easier for R&R.
Good luck.
David
allbee 12-19-2008 06:35 PM
Good luck.
David
that's right where I put mine but put in nut plates, no.6
dhall_polo 12-19-2008 06:38 PM
platenuts
I added platenuts to the flanges of the ignition module for easier removal in the event that service is required. I'm probably also going to change out the screws on the serial connectors with the kind that allow hand twisting.
Don
odlee 12-19-2008 06:47 PM
Don is right on the mark.
I also used thumb screws on the connecters where possible. Not a big deal until you put the top skin on! Then you'll be happy you did.
David
Rick_A 12-19-2008 07:31 PM
I put a hinged shelf in the same general location. The hinge is on the firewall angle and I've got 3 nutplates on the sub-panel.
I have other components mounted on the ribs, so I needed to create some extra real estate behind the panel.
cjensen 12-19-2008 08:20 PM
Here's where I put mine...
...used plate nuts #6.
:cool:
flion 12-20-2008 06:56 AM
This is mine:
It's a great location with one small caveat: due to my lack of foresight I located the boxes on the top side of those angles, making it difficult to work on them or remove them once the top skin was in place. I'd use the location again, but I'd turn the aft angle around and mount the boxes on the bottom side so I could just unscrew them and drop them down.
