school me on fuel injection systems (standalone user here)
ive had a standalone engine management system in my car for a few years now, and have done all the tuning myself.
www.034efi.com <- im using the stage Ic anywho, its wastespark, sequential injection... the works ive seen SDS installed on RV's before... 034 is a great system, but its really meant for automotive systems and specifically for bosch sensors.... i doubt there is alot of user programmable systems out there, but i have no idea what are some of the better engine management systems out there people are running on the 360/540's? |
I'm not aware of any other programmable EMSs being used on Lycoming engines. Most FADECs offered are pre-programmed for certified engines.
DG's Lancair racer with the Conti had a Microtech EMS fitted in 2007 but it was removed this year with the team reverting to the troublesome mechanical system. http://www.microtechusa.com/ Nemesis had EFI type fuel rails installed I assume for future use of the IE2 FADEC in the wings from Lycoming maybe for next year but they were running mechanical injection this year as well. IE2 should be available next year for some models of Lycomings. Precision Airmotive offers the Eagle EMS: http://www.precisionairmotive.com/ for experimentals. Aerosance has offered a system for Contis for some time but it has never caught on well and some of the sites with info on it now are dead links: http://www.tcmlink.com/aerosance/ The Thunder Mustang has used Motec for many years: http://www.motec.com/home One of our vendors is currently working on a kit for 320/360 Lycomings using SDS hardware. Flight testing should be commencing early January in California. We've fitted SDS to a handful of Lycomings and Continentals over the years and they work well, including Mike Dacey's 375 mph Questair Venture at Reno this year. No reason why the 034 should not work in an aircraft, just watch what sensor failures might do to engine operation. |
Tracy Crook at Real World Solutions can set up his EFI for a Lyc, if you're willing to install bungs for automotive injectors.
http://www.rotaryaviation.com/eficont.html Charlie |
Hans |
For the DIYers, you could arrange something really redundant fairly easily - consider a simple case with a whizz-bang ECU squirting fuel and firing the plugs. Add an engine monitor that picks up each cylinder EGT (and others ideally) and if it picks up out-of-range values, it switches over (with pilot confirmation) to an alternative ECU from a different vendor: As an extreme example, a Motec M600 with sequential injection + ignition, and handover to a MicroSquirt with batch fired fuel and an e-mag for the ignition. The latter set would run off your backup alt & electrical bus. Cost and weight overhead should be fairly minimal. You just need to monitor the engine vitals yourself... until MGL or Vertical Power or Someone Else steps up with something to help there... BTW, be thorough when you evaluate an EFI system (or any system for that matter). Check that they're using at least automotive or military grade components. Check that they validate their software and hardware against known standards, and that they adhere to a known development process. This isn't a dig at any vendor in particular... just think of it as analogous to selecting the right materials and having a quality process for the design and manufacture of a mechanical component. |
In 14 years of aviation fuel injection experience we see a lot more engine shutdowns caused by sensor anomalies and inappropriate code designed to protect the engine, especially in the case of OEM units. Hence my point about knowing how the system will react in the case of various sensor failures. If in doubt, simulate at full power during ground testing by disconnecting or shorting sensors one at a time. You don't want to be flying a system which goes full rich if an engine temp or IAT sensor fails open for instance. There have been some good articles this year in Contact! magazine on EFI failure modes, especially relating to OEM systems. |
In an ideal world, we'd go back and review against IEC 61508, DO-178B, DO-254, ARP4761, ARP4754, MIL-STD-882D, etc... but that's not going to be cheap, and perhaps not practical. However selecting the right components / connectors / materials, running static analysis tools over the code, and getting out the pen and paper to document everything is pretty easy (if uninspiring!). Quote:
I have the Eagle EMS system from Precision which includes both electronic fuel injection and electronic ignition. It has completely redundant systems including dual computers and sensors and utilizes it's own battery backup. A really nice/clean setup and all components are made to install on the engine side of the firewall.
Aerosport is the most experienced engine builder supporting this system and they have done a lot of dyno work with the system on 320s, 360s, and 390s. |
| All times are GMT -6. The time now is 04:36 AM. |
