VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   K&N Airfilter for Van's Carb air boxes.. (https://vansairforce.net/community/showthread.php?t=3635)
Wicked Stick 10-11-2005 04:41 PM
Anyone have a fix or resolution of a way to eliminate having to cut a notch out of the K&N air filter where it fits over the accelerator pump of a vertical carburetor Van's airbox setup ???
We've recently purchased an RV-4 with an O-320 in it that's carburetor equipped, and discovered this when we removed the filter to clean and re-oil it.
Just wondering if there's a better way to do this then having to cut a notch in a perfectly good air filter.
kevinh 10-11-2005 07:17 PM
At least on my O-360 and carb:
If you are careful when you align the airbox and install the filter 'keepers' on the top plate you don't need the notch. It took a bit of sliding to find where to put the airbox so the notch wasn't needed and the airbox was still clear of the cowl/gear.
Of course this only works when you are initially building (or rebuilding) the airbox.
