VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Annual Inspection Checklist (https://vansairforce.net/community/showthread.php?t=35819)
Capflyer 11-04-2008 03:38 PM
Well....it's been a fantastic year and I have loved every moment of the 165hrs put on my RV in its first year. At the end of November it will be time to take her down for the first annual.
It would be great to follow a checklist to be sure I get everything covered and while doing the first one, take the list and customize it to my plane. Would any of you care to share your annual inspection checklists?
Thanks in advance.
brianwallis 11-04-2008 04:33 PM
I got you covered!
Here comes a checklist I use for annuals. The only thing it does not have on it is fuel injectors. Make sure you check the lines for a max bend radius of 5/8 inch on the inside of the bend(lyc). Also... if you put the injectors in a cleaner like they use for jewelry (electrosonic) then don't let the cleaner material come in contact with any water. Also on the injector, make sure you don't drop any small parts out of the injector or the fuel pressure gauge will act like it's a pinched line. On a cautious note, I always have someone double check my work even though I hold the IA ticket, I hope everyone else does the same.... If you have any questions, please let me know. I'm more than happy to answer any questions you have for free.
PS.... If anybody else wants the checklist, I email it for free!
Best
Brian Wallis
404-405-1315
ghatch 11-04-2008 05:27 PM
Hi Brian,
I would like to have a copy of you checklist also. Thanks.
I'm about 4 months away form first flight... RV7 IO-375 c/s w/dual GRT HX, TT GSGV and lightspeed ign.
Gerry Hatch
plumbflyer 11-04-2008 08:15 PM
inspection list
Hi Brian, I also would like the list.
celstar 11-04-2008 08:44 PM
I also would like a copy.
Thank you.
ao.frog 11-05-2008 05:09 AM
Me too please:: ao.frog@c2i.net
Thanks.
Flyin Brian 11-05-2008 07:25 AM
Check List
Me Too!
brianocm@bellsouth.net
Brambo 11-05-2008 07:42 AM
Me too please. :)
brambo2@cox.net
N941WR 11-05-2008 07:59 AM
Here is a link to the document I used on my -9...
RV-9 Condition Inspection
(Doug, feel free to grab a copy and put it on your POH page.)
N55CU 11-05-2008 08:24 AM
Annual Checklist
Thank's Brian, me too! randy@djdist.com
Randy Utsey
RV-7 / 155hrs
