VAF Forums
-   -   Crack in engine baffling (https://vansairforce.net/community/showthread.php?t=35747)
whifof100ll 11-02-2008 09:00 PM
I found that the baffeling has cracked behind #4 cyl where the engine baffle turns outward and the oil cooler is attached. Obvoisly the weight of the oil cooler shaking around on the back of the baffeling is a bit much for the aluminum. This is the second side by side RV I have seen this happen to.
This is a standard Van's setup using Vans FF kit for the O360. The airplane only has 130 hours TTSN.
Is is common? Anybody have experiece with a successful repair?
Regards,
Geico266 11-02-2008 09:09 PM
Pretty common. You can stop drill the crack and add doubler plate. Look at where the crack is originating from. Is there a washer missing or screw head setting up stress on the baffling?
N941WR 11-02-2008 09:12 PM
Dale,
That is common and there are a few solutions.
1. Relocate the oil cooler to the firewall.
2. Add a rectangular cap where the baffles joggles to go around the cylinder head and the oil cooler is. This also makes installing the baffles easier as you only need a straight piece to span the entire back baffle.
3. Add a support/stiffener.
My solution was #3. Here's are two pictures:
Note, this is an O-290 and the screws to hold the baffles in place on the cylinder heads are in different locations than on an O-320 & O-360 so you may notice some other changes required to make the Van’s baffle kit work with this engine.
L.Adamson 11-02-2008 09:16 PM
The solution.....
This is a former aileron push rod.
L.Adamson
Rick6a 11-03-2008 04:28 AM
Dale,
The failure is typical of the OLDER style baffle kit that used aluminum for the oil cooler area. You can repair the damage conventionally using a variety of options including reinforcing the area with doublers, angles, stop drilling, installing a brace, etc. I beefed up that area considerably when I assembled the baffling because I read so many reports of cracking. With 230 hours on my O-320 now, the older baffle kit area includes a steel brace and still appears very secure. That is not to say it won't fail sometime in the future.
You may also want to consider purchasing three key pieces of baffling NOW improved using a much harder T6 alloy. Of course the repair will be more expensive and take longer because of the rework involved but only you can decide if it is worth it or not.
N520TX 11-03-2008 07:21 AM
Part Numbers
Rick - do you have the part numbers for those steel pieces handy ?
Rick6a 11-03-2008 07:54 AM
Brantel 11-03-2008 09:35 AM
Rick,
Are you sure those three parts are stainless?
I have the new baffle kit and although those parts look like different material from the rest of the kit, they do not look or feel like stainless.
Anyway to tell for sure?
Rick6a 11-03-2008 10:08 AM
Brian,
Well, to answer your question as best I can, let me say this. I would decline to testify in court as a metallurgist but when the time comes for you to cut, snip, drill or even try to file or sand an edge on that hard material, it will become abundantly clear you are not dealing with aluminum. It machines and works like you would expect of thin steel sheet. The only thing I can see it has in common with aluminum is its non-attraction to your average magnet. :)
Brantel 11-03-2008 10:50 AM
I hear you Rick,
I know it is different but not sure what it is.
Paul Merems and I had this same question with each other last night on the phone.
Maybe Joe or Bruce from the factory could clear this up for us???? :confused:
David-aviator 11-03-2008 11:40 AM
Originally Posted by Brantel (Post 268497)
Rick,
I am installing a new 0360 baffle kit at this time, the parts are aluminum in this kit.
But the oil cooler part is being skipped. It will be remote mounted and ducted with 4" SCAT from the #4 baffle.
vlittle 11-03-2008 12:45 PM
Here's what I did with the old baffle kit.
Vern
Rick6a 11-03-2008 12:49 PM
Brian,
I called Van's. Most of the aluminum we work with is T3. The three improved baffle parts are now fabricated using a much harder T6 alloy. I amended my original post to correct the information and regret any confusion I may have caused.
Brantel 11-03-2008 02:06 PM
Thanks for the research Rick!
az_gila 11-03-2008 06:36 PM
Rick - Is it the...
Originally Posted by Rick6a (Post 268554)
Brian,
...same 2024 alloy, or is it the more common 6061-T6? - which is also cheaper.
IIRC, the Bingelis books recommended the 6061-T6 stuff for baffles.
You should be able to buy it locally from your industrial metal supply store...
