PCU5000 and Van's VA-153 mounting bracket problems
Fellow builders,
I need your help. I received my FWF kit a few weeks ago and decided to return the MT governor and purchased a PCU5000 governor instead. I read the posts and talked with the PCU folks and Van's and it appeared the VA-153-PC bracket should work. In fact there are several postings saying the it dropped in without any modifications. Well that is not the case with the VA-153-PC bracket and the PCU5000 in my case. See photos attached. Many of the posts I reviewed had the old style governor bracket. This bracket mounted to the base flange of the governor. The current bracket mounts from the rear of the governor. I was told by Van's that this is the only bracket available and the reason they changed the design was to give more access for the oil lines. Here are my issues: 1. The holes don't line up and need to be slotted to match up. 2. The inner radius of the bracket doesn't fit and would need to be enlarged or a spacer needs to be placed between the bracket and flange (see photos). 3. With the thickness of the bracket and spacer one of the screws hits the stop bolt. This interference occurs with the stop ring in the proper position with respect to the control cable travel. Possible fix: remove spacer, grind down radius to fit PCU. This would only eliminate 0.063" of the height issue. but would leave very little edge distance for the mounting holes to the radius. 4. I can not get the AN3-11A bolt into the control arm due to it interferes with the flange on the PCU. This may not be a unique problem for the PCU (Any MT owners with this issue). Bolt shown is a AN3-10A with a temporary nut install. Possible fix: grind down one side of the head of bolt to clear the flange. Any help would greatly be appreciated. |
Same exact issues
Paul,
I found the same issues you did. I figured my bracket must be from a bad batch from Van's or something. I was about to write them an e-mail tonight describing the issues when I stumbled across this post. Everybody that participated in the PCU-5000 group buy will be experiencing this same issue sooner or later. I believe there where more than 50 of us. I finally got mine in the mail today. Since I see your post was a couple months ago, have you come up with any better solutions? Otherwise I'm going to get out the set of files and get to work. -Brad Vier RV-8 FWF |
had the same issues...
at least the bracket is a good start. but could just as well be perfect from the start... wouldn't cost that much more... unfortunately, you will encounter more of that... my experience so far has been everything firewall forward had to be somewhat tweaked, filed, etc... to fit. even the new style baffling kit is still a pain. and the latest example is the filtered airbox fiberglass snorkel that needs quite a bit of adaptation to the oil line going from the crankcase to the cylinder head. bernie |
I just did this.
I just experianced this on my RV-6.
Paul created some of his problems by first adding a spacer under the bracket. This is what I did. First, file the radius to fit, mine just needed a little tweaking at each end, this helps the holes aline better. Second, use a small round file, like a chain saw file to elongate the screw holes. It doesn't take too much, but it does elongate the holes some. I installed thin washers(3)under the screw and original lock washer to cover the elongated holes....looks very professional. Third, I reversed the direction of the bolt and adjusted washer locations accordingly. Everything adjusted up just fine, although I haven't run it up yet or flown it. Good Luck |
VA-183-PC
The VA-183-PC bracket the Vans use to sell works very well. Maybe Vans could tell you who they used as a supplier for the VA-183 bracket.
I got mine yesterday. Thanks for the heads up.
Does the PCU5000 from the group buy come with the gasket? I guess mine should be arriving this week.....
Mine did!
| All times are GMT -6. The time now is 02:35 PM. |
