VAF Forums
-   -   Push Button Starter (https://vansairforce.net/community/showthread.php?t=34235)
vonjet 09-17-2008 09:34 PM
Push Button Starter
Anybody used one of these cool push button starters in their airplane? I am using a push button start and Id like to find something unique. Anybody know if these will work in Aircraft?
http://www.sfxperformance.com/parts/IGN2001B.htm
Mike Ice 09-17-2008 09:51 PM
starter button
Vonjet,
I can't imagine why one of those buttons wouldn't work and they look pretty cool. Go for it. It is your plane.
Mike Ice
JohnJacobsen 09-18-2008 04:35 AM
How big are they? Couldnt find any specs.
Geico266 09-18-2008 05:29 AM
I have flown planes with push buttons and from a safety stand point they are not a good idea. There is no key to lock the aircraft's ignition. Anyone can get it the plane turn on the master and push the button. :eek:
Story Time: I am reminded of SnF a few years ago where a customer was sitting in a light sport display plane and said; "What does this button do"? The Rotax 912S engine started full throttle, plane shot across a busy area, hit a ditch, went airborne, and then crashed into 3 cars. :eek: Push button stater? NOT a good idea in an airplane.
Go with the key lock. When the key is on dash or in your pocket the plane cannot be started.
Mark Castle-Smith 09-18-2008 05:53 AM
The specs from the manufacturers web site are as follows:
Switch Acutation Style: Push Button
Circuit Activation: Momentary
Amp Rating: 10A
Volt Rating: 12V
Terminal Type: Screw
Material: Plastic
Quantity: Sold Individually
Mounting Size: 24mm or 31/32"
Note that the he amp rating on the specifications does not say whether this is a rating for a resistive or inductive load
On face value this switch should be fine, especially if it has been design to control a car's starter contactor. However I would call the seller to clarify (don't mention it is for an aircraft!) as a contactor is a highly inductive device that is very hard on its controlling switch (don't forget to install the spike controlling diode).
However I do agree that installing a push button switch without protection is probably not a good idea in an aircraft, but if you want the look of this switch you could always protect the starter circuit with a hidden switch or using a simple SPST key switch in the circuit.
Mark
Mel 09-18-2008 07:08 AM
Don't count on it!
I have seen MANY aircraft ignition switches that were worn enough that the key would come out with the switch in the "left" position. I had a friend whose Swift started with a small turn of the prop. The airplane had been sitting for days and the mixture was at ICO.
bsacks05 09-18-2008 07:36 AM
I love my push to start button from B&C. I also keep a throttle lock on when I'm not in the plane. Come to think of it though, wouldn't a mixture lock be better?
mannanj 09-18-2008 08:02 AM
Push Button
According to the item description, it requires a key to illuminate, and I suppose arm the starter button.
Go for it!
Sam Buchanan 09-18-2008 08:09 AM
I too am a fan of the push-to-start switch. I have had to dig the ignition switch key out of my pocket after getting buckled up...........zero times! :D
Never worried about unauthorized or accidental use of the plane. Hardly anyone can figure out how to get past the tip up canopy latch. :)
N520TX 09-18-2008 08:29 AM
S-2000
My Honda S-2000 has a starter button - when I test drove it yrs back I thought it was the coolest thing. When I started work on my 7a back in 2003, I just knew it had to have one as well. I managed to locate a genuine honda starter button (http://www.handa-accessories.com/s2000-03.html near the bottom of the page) and sure enough, it's in my 7a. It's not rated to carry the starter current itself, so a relay was required.
