LASAR and UMA Tach
I have the LASAR ignition and the electric UMA tachometer found in vans website. I have the brown wire from the lasar hooked to the tach white wire but I get no tach reading.
I review the information from lasar and uma (uma-19-806-11G) and unhooked the brown wire and moved the white wire to the "L" mag position on the switch. This works, but only if the lasar is off. As soon ans I finish the mag check and the lasar comes back on-line the tach output goes back to zero. Does anyone have the lasar system running a uma electronic tach? Is there a compibility list from either lasar or uma? Thanks- Jim |
Thanks-
I will give him a call first thing Monday! Thanks for the contact info!
I have the same problem
I'm having the exact same problem, could you pass on the contact info to me as well. Thanks
| All times are GMT -6. The time now is 04:15 AM. |
