Adhesive for Interior Panels
I tried with miserable results to use 3M 77 spray adhesive to attach my interior panels that are vinyl covered corrugated plastic boards. The vinyl sticks great with the spray glue to the plastic but will not stay attached to the aluminum.
What are others using to attach their interior panels to the aluminum that will not corrode it over time? |
hummmm...
I had the same problem. I hope that the Shoe Goo that I used won't effect the AL.
Kent |
Airtex
DURASEAM TRIM CEMENT Bottom of the page.... http://www.airtexinteriors.com/catalogue/misc.htm It's a old style contact cement full of VOCs... which seems to be better than the newer stuff you can buy at the hardware store...:) It's even made for airplanes, and works well on the vinyl of my Tiger in the AZ heat. |
Adhesive backed self stick velcro strips.
By the way, clean the alum with mek, or acetone first. |
I had similar problems getting 3M 77 to work as well. Switched to 3M 90 and it worked great.
Are you gluing these panels to the skins or to Velcro pads so they can be removed for future inspection?
There is a chance that by gluing your covering right to the aluminum, you could trap water, oil, and dirt there causing future problems. By mounting them on Vecro tabs, you can remove the covering for inspectiona and future wire runs. Just a thought. |
| All times are GMT -6. The time now is 04:05 AM. |
