Filtered Air Box for Airflow Performance
Does anyone know of an aftermarket company that makes a filtered airbox for an IO-360 with the Airflow Performance injection similar to the one Van's sells for the Bendix injection system? Thanks.
Dan |
Dan, what's wrong with the Vans FAB? I have the same setup (with the FAB-360/540 airbox). The Airflow Performance FI system will come (mostly) complete with everything you need for installation.
Although mine is on an IO-540 with an AFP setup and purge valve, I used Van's standard FAB and it worked fine. I believe the FAB from Van's works for all the vertical induction setups, 360 & 540's. Oh, and you don't have to build in that little offset for the mixture or throttle arm...whichever one it is you have to do that for :)
Filtered Air Box
My IO-360 is horizontal induction so the FAB will not work. Van's makes a snorkel for the Bendix injection unit but not for AFP.
Dan |
not sure if this is what you're after, but try this. . .
http://www.ramairforhomebuilts.com/default.htm |
Dan Checkoway modified Van's box to work:
http://www.rvproject.com/20030803.html And some more later posts, look in his build site. |
Thanks Stephan, That's what I'm doing right now. It would seem because of the popularity of the AFP that someone would be making one but I guess not. I'll keep hacking away.
Dan |
| All times are GMT -6. The time now is 12:01 PM. |
