Collaborators Team Negative G formation
I saw something this week at Oshkosh that I've never seen before - negative g (non-lead) formation flying. I'm not saying it hasn't happened before, I've just never seen it.
The Collaborators did a maneuver with all four members pushing hard negative g's while in formation. While it is common for the lead to be negative, I've never seen wingman negative (I might have seen a Blue Angel two ship with wingman negative, but not too close and directly behind lead). This would seem to be more difficult than it appears , since the wingman has to bank "toward" lead to move away. In other words, if aileron is used, the stick would be moved towards lead in order to move away. I'm wondering if the wings are simply kept level, and perhaps rudder is used to move closer/further from lead. Anyone know how they do this? BTW, I have no interest in doing this... |
Deven, if you are flying off someone, and you are positive g, you will move the stick away from the lead plane if you want to move away. This will reverse if you are negative g. Use your hands and imagine what needs to happen.
More Snowbirds video here. The video from the middle of 9 plane diamond during approach and landing is especially impressive. How they do it? I've never done inverted formation, but there is a Pitts formation team based at my airport who do it once in a while. I've talked to Andrew, the wing man about inverted formation in the past - you simply need to understand how the relationship between bank angle and movements to and away have changed, and do lots of practice. |
Kevin, thanks. The mirror roll video is unfortunately not a continuous video all the way through the maneuver. I do not see in that video that the wingman is ever negative g. Only way to tell is through the curvature of the smoke. I believe you that they do it, but the video doesn't tell the story...
My bet is still that they use rudder... with your connections I'll bet you can find out from the source! |
That's not trivia
| All times are GMT -6. The time now is 10:37 PM. |
