VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Lightspeed/Lycoming 4 cyl direct crank install (https://vansairforce.net/community/showthread.php?t=32108)
LifeofReiley 07-16-2008 03:46 PM
Well... I've put it off long enough and would like to see if anyone has pics and documentation on installing the Lightspeed Direct Crank system on a Lycoming. I still need to drill the flywheel and install the plate... from the start as you might say. HELP PLEASE!!!! :eek:
Makes me nervous just thinking about it...
Thanks in advance!
Allen Barrett 07-16-2008 03:53 PM
Klaus
will drill the ring gear and install the pickups for 50.00 (+freight). Go to his web site there are directions there, or used to be.
Allen
scard 07-16-2008 03:59 PM
I did mine in the shop. Measure more than twice, drill once. I think there are a few pictures and commentary somewhere on my build log. No big deal. Ok, I actually made a full size template in autocad just to double check my measurements. Sanity check. It is all about that angular alignment.
LifeofReiley 07-16-2008 04:07 PM
Hello Scott,
Yes, I remember now... you did the change over. How does beer and ribeyes sound? I know your work is awesome... Can you help a fellow out? :):):)
scard 07-16-2008 04:28 PM
Just draw yourself up a template (picture in the post below) and go for it:
http://rv9a.card-net.org/archives/20...-fwf-progress/
Be careful with the magnets, if you tap or press them too hard, they'll break. You only get one shot at it and I don't want to be anywhere near if it doesn't work out :).
AlexPeterson 07-16-2008 05:31 PM
transfer punch
To properly locate the holes to be drilled in the crankcase, get a set of transfer punches. (Search for them if you don't know what they are.) Get the proper size numbered drill for the thread (IIRC, it is 1/4-28?). Get a high quality thread tap, and experiment on some blocks of aluminum if you aren't comfortable with tapping threads. Get a good aluminum tapping fluid, Tap Magic makes some.
Hold the mounting plate in position, and have an assistant transfer one hole, using the transfer punch, to the crankcase. You may need to space the plate away from the crankcase a small amount to get the transfer punch to be fully engaged with the mounting plate. Remove the stuff, and drill a small pilot hole, maybe a 3/32" hole or so, then drill the tap size. Tap this hole, and then mount the plate again on the engine using the one bolt. You may need to put spacers under it to allow the transfer punches to properly engage, and then transfer the remaining holes. Tap away and that part will be done.
Send the pulley thingy to Klaus, well worth the $50.
LifeofReiley 07-16-2008 07:44 PM
Thanks Alex!! You're always on spot with info. Flywheel will go to Klaus, we will then feel our way SLOWWWWLY thru the rest. Wish there was more support on this install locally.
Radomir 07-16-2008 07:58 PM
Darrell, while you're at it.. ask Klaus to install the bigger magnet (1/4" size) on the flywheel.. I like that option as it gives you more range for the gap and is there in case you ever decide to go dual LSE...
LifeofReiley 07-16-2008 08:16 PM
Awesome info... did not have have a clue about this one! Will discuss this in the morning with klaus. I will probably go dual with-in a year of flying. Thanks!
flion 07-16-2008 09:00 PM
Another option, depending on how close you are to the Dallas/Ft. Worth area is to ask Superior how much to do it. They've got a jig; we did mine in minutes, while I was at the build school, for dual LSEs. Great people to deal with but I really have no idea how much a shop job like that would run. They might also be willing to drill the crankcase bosses if you need it; can't hurt to ask. Check out the thread on Lightspeed Wiring Specs, too.
