Another dumb question?
I've read in a couple of places that I should use insulating washers when installing mic and phone jacks to keep things from grounding to the panel, but doesn't the threaded portion pass right through the panel and thus come in contact with the hole itself?
Steve Zicree RV4 with lots of dangling wires |
Insulated washers
Nope, the insulated washers I'm thinking of sit in a larger hole than the threaded part of your jack. One half of the washer set has a protruding chunk which fits into the larger hole, and the other half is just a flat washer. The jack itself is totally isolated.
B&C sells these washers. http://www.bandc.biz )_( Dan RV-7 N714D http://www.rvproject.com |
Thanks a bunch Dan. I thought it might be something like that. Watch for more novice electrical questions real soon :D
Steve Zicree |
another dumb question #2
btw, just put my phone jacks in, hopefully I got it right.
hey, it's Sunday, I can't find an alternator belt, can I still go ahead and mount my prop? |
prop off, belt on
wait on mounting prop
Mark,
If you mount the prop, you will then have to remove it in order to get the alternator belt on. |
More Electrical Confusion
I'm trying to decifer all the various installation guides for my panel and came across this one for the intercom
http://www.ps-engineering.com/docs/P...ng_diagram.pdf If I'm reading it correctly it calls for multi-connector wire with an outer shield. The diagram seems to show the shields for each jack all being connected to each other at the Sub-D plug. I'm hoping somebody with more experience than me (that would be any at all) can tell me exactly how all those shields are actually connected together. Thanks folks. sTeveZicree RV4 that you can sit in, but not much else |
too many grounds too few ground pins
http://www.aeroelectric.com/articles.../d_solder.html http://www.aeroelectric.com/articles...l/pigtail.html (SEE STEP 7: daisy-chaining of shield grounds) G |
G,
Dang, a picture really is worth... well, you know. Thanks so much. I've read Bob's book, but didn't realize there was so much great reference stuff on his website. Hey, as long as I've got everybody looking at my intercoms's diagram http://www.ps-engineering.com/docs/P...ng_diagram.pdf can somebody tell me why it seems to show the shields connected only at the intercom end. In my limited experience I've always used the outer shield as a conductor but here it doesn't appear to be the case. Am I making any sense? Steve Zicree |
Jeff Point RV-6 Milwaukee |
| All times are GMT -6. The time now is 06:56 PM. |
